Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
In 2012, Sony Entertainment announced that the company would be releasing a new version of its 2006 Playstation 3 console. The new console is call the Playstation 3 Super Slim and is identified by the model number, CECH-4000. The PlayStation 3 Super Slim (CECH400x) is the third version of the PS3 video game console produced by Sony Computer Entertainment. It was released October 25, 2012.
193 Vragen Bekijk alle
Why won’t my PS3 Turn on
I tried turning on my console by controller and it wouldn’t turn on. So i thought that was weird and so I pressed the button on the console. I press it and nothing happens. No flashing , beep, green light, fan spinning. The red light is solid. I took the ps3 apart and cleaned out all the dust and I put it back together and it still wont turn on. I tried unplugging it for 20 seconds and even a whole day and nothing. I pressed the button and held it for 20 seconds and nothing at all and only the red light stayed.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Hello @derick_f1774
What you have is commonly referred to as the Red Light of Death for PS3 consoles. It is caused by the PS3 overheating.
I’ve had this issue before as well and there are tons of guides on how to fix it. My best recommendation to you, if you feel comfortable enough to take it apart, would be to simply replace the thermal paste application on the CPU and GPU inside of the console. Clean off the old thermal paste and apply new then test once the console is put back together to see if it works.
This is the only thing that has worked for me in the past, I’ve tried putting it in the oven or on the grill, and all the other tricks you can find on the internet. But simply replacing the old thermal paste, re-seating everything, and turning it back on worked for me.
Here is an article on how to tear it down. PlayStation 3 Super Slim Teardown
In step 13 you will find the relevant information. Hope this helps.
Was dit antwoord nuttig?
Commentaar:
I have taken the PS3 apart and the thermal paste is actually still pretty pasty. I have cleaned all the dust out were the fan was. I unplugged everything and plugged everything back together and it still won't turn on.
door
Sad to say then it most likely got so hot that the CPU/GPU died. You can try some of the more unorthodox methods that you can find on YouTube to see if you can fix it, but if a fresh application of thermal paste and cleaning of the dust didn't fix it, it could be a few other things that are hard to track down.
Sorry I wasn't able to help more.
door
Voeg je antwoord toe
Derick Figueroa zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 19
