Ga door naar hoofdinhoud
Released September 21, 2018. Models: A1921, A2101, A2102, and A2104 / Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray (Pronounced "iPhone 10 S Max.")
373 Vragen Bekijk alle
Replacement XS Max screen won’t fit. Why?
I’ve an iPhone XS Max with a busted screen. I ordered a replacement but the screen won’t fit. It has these little tabs sticking out all down right hand side but existing screen doesn’t so there’s nowhere for these tabs to slot into.
Can anyone tell me why or how to get around this please?
thanks.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Your tabs are stuck in the phone, you have only lift up setje front of the screen and the metal frame of the screen is still inside the iPhone. You first got to get them out before you can instal your new screen.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
You’re absolutely right! Problem solved and new screen installed. Thankyou ??
door
How do you take the tabs out?
door
have you ever had your screen replaced by a shop or anything?
in the guides ive seen all the replacement screens have the tabs… thats how it holds to the body of the phone.
iPhone XS Max Vervanging van het scherm
follow that guide and see if you can get it reattached that way.
Update (03/31/2021)
heres a few more tips for getting this thing reattached
https://www.iparts-4u.co.uk/blog/iphone-...
3 opmerkingen:
No never had screen changed. Bought phone from cash converters when it was 6 months old. It was in new condition.
It’s really odd that the replacement screens won’t fit. I’ve run the serial number through Apple and it all checks out ok so I’m baffled?
door
@dragon2273 only thing i can really suggest is either the phone is a REALLY good counterfeit OR there is something jammed in some of the slots where the "pins" on the screen would fit? maybe use a magnifying glass and check to see if theres gunk or something in there?
door
Merci de votre réponse
si je comprends bien il faut enlever la plaque lisse qui entoure le téléphone pour retrouver les ancrages ?
je ne veux pas faire bétises
door
Voeg je antwoord toe
dragon2273 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 34
Altijd: 1,573
