iPhone 11 Pro earpiece is rattling. How to fix it?
My iPhone 11 Pro earpiece is rattling and has thin sound. How could I fix it? Should I remove the sensor array and and clean the speaker with alcohol?
Is dit een goede vraag?
Definitely try cleaning everything out with some alcohol, and make sure that you’ve removed all of the adhesive that may be underneath any components and use some fresh adhesive. If the quality of sound is still bad, then you may need to replace the earpiece speaker, which unfortunately comes with the FaceID, meaning replacing it would render FaceID inoperable.
Was dit antwoord nuttig?
I removed the display and noticed that the speaker grill was blocked. Used mix of air and isopropyl alcohol to clean it.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 420
