Which screwdriver for replacing ram and hard drive?
I will be purchasing the latest MacBook Pro 15. I will be replacing the RAM and the hard drive. Will I only need one screw driver for both tasks and if so where can I order it for the cheapest (including tax and shipping). Does not need to be high quality as only will be using once or twice. Thanks!
Is dit een goede vraag?
1 Opmerking
I did some research as I work on Macs all the time and definitely found an outstanding small Philips screw driver to work with the small little case screws found on the aluminum Macbooks.
The screw driver is made in Germany by Wiha
The model is from their 261 Philips Precision series.
wihatools.com
Tip size is 00 and length is 40 mm.
The end of the screw driver swivels which makes it very easy to work with.
The quality is very high.
Got it from Amazon … search for B0006OBFOA
door rws70
