Ga door naar hoofdinhoud
Google's third-generation Pixel-branded smartphone, and their first "notched" phone. Comes with a 6.3" QHD+ OLED display and 64 or 128 GB of storage. Available in Nearly White, Just Black, or Not Pink.
77 Vragen Bekijk alle
Replacement screen doesn't power up?
After a drop, screen was badly cracked but still functional. I ordered the ifixit replacement screen and also a replacement battery.
Replacement was uneventful. I reassembled without adhesive to test fit and confirm everything was working. Screen stays dark. If I press the power button I get the haptic vibration indicating that “power off” options are on screen. Holding the power button for 20 seconds gets another vibration consistent with a power cycle. I’ve tried putting the screen under a very bright light to identify if its a backlight problem, but I can’t see anything at all — seems to be completely dead.
The repair was straightforward — I don’t know of any point when I might have damaged the replacement screen. Other possibilities?
Update (03/11/2021)
iFixit is sending me a replacement screen. Hopefully it will work properly.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Mb phone is in edl mode after drop. Check the UFS modules, if is good (not damage). You can download a QFill or other, and flash it.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thanks Jatva. It's not in EDL mode, but I appreciate the suggestion.
door
How did you check it?
door
Voeg je antwoord toe
Dan Strunk zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 50
