Ga door naar hoofdinhoud
Asus Rog Strix Scar doesn't want to work with open back panel
Hi guys, is it possible to use the laptop (Asus Rog strix scar G733Q) with open panel? I am doing some mining when not using it for gaming or work and would like if you share with me how I can use it with open back panel and preferably disconnected battery.
Disassembling and assembling back the laptop is not an issue. The problem is when the back panel is away from the laptop it doesn't want to start at all. As soon as I put everything back together the laptop is starting like nothing happened.
Is dit een goede vraag?
2 opmerkingen:
Just curious. Why would you want the back panel off?
door
Better cooling. Don't want to burn down the machine while trying to pay for it with mining...
door
Voeg een opmerking toe
1 Antwoord
You might be able to find a bios option that would allow you to do this, otherwise look for a switch or button on the board that senses if the panel is on and put a piece of tape on it.
Was dit antwoord nuttig?
Voeg je antwoord toe
Vas zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 104
