Ga door naar hoofdinhoud
Een uitgebreide verzameling reparatiehandleidingen voor elektronische toestellen, van audio-installaties tot rekenmachines.
14903 Vragen Bekijk alle
Which conductive ink would you recommend?
I know this is a bit off topic, however it is repair related. I have an iBook that I am trying to repair. The power connector ripped off the conductive pads, the trace snaps if you go near it with solder! I tried a conductive glue but am not happy with the results, it is waterbased and difficult to control where it's going. I put it on the board but have since removed it because I don't think it will work blah blah blah.
So..this is what I originally was looking for, a silver conductive pen so I can "write" the connections with accuracy. Anyone know whether it's good, recommend anything else?
Is dit een goede vraag?
Score 2
Commentaar:
What glue did you try to use? Why did you feel it would not work? A picture of the traces you are trying to tie into would be helpful.
door
It was unbranded... Waterbased,dark grey colour,spread and didn't hold a shape so that when I tried to "paint" it from a to b it tried to spread to c. This goes with a question on an iBook g3 I asked about 2 weeks ago. I've been helped by Markus weiher about making new points for connection, but need to repair some broken trace from where the power connector pulled off the motherboard. The pictures are on that question, I'm hoping that this idea will solve the power issue and I can then sort out the boards other problem!
door
Display black /are there any vital screws? this is the little PITA board I'm trying not to junk. I don't like quitting...
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I couldn't find the thread with the pics, though I vaguely remember it. The silver trace pen you have a link to is good. However not the best option for fine work, but can do it with a "form". It will "pool up" somewhat as you mentioned with the glue you are using. What I suggest you do is take tape and put it on either side of where you want the trace to be. That will make a controlled channel for either the glue you presently have or the material from the trace pen to reside in. By doing this you can get your trace from a to b and control c. Leave the tape on long enough for the substance to just start to get tacky, but not dried yet, and pull the tape up. That should leave your trace from a to b with no c.
Added with edit:
I would solder a fine single strand wire to the trace and rebuild the solder pad. Here is the main solder I use. Most armatures can get a professional looking solder joint using this solder paste. It melts low profile on the metal. The gist of my review there says this about the product: It is a great low heat solder paste, melts at approximately 183 °C (361 °F). The metal content by volume is somewhere around 90%, based on the character of its performance. It has great viscosity. It sticks where you put it. The product consistently produces a strong, neat bond with low heat.
I would scrape off coating from a small section of the existing trace. Then apply a small amount of the solder paste to that area and hit it with the soldering iron to tin it. Then rebuild the pad with a small piece of copper foil cut off a copper pot scrubber. I would apply a small amount of the solder paste with a toothpick to both ends of the fine wire and the new pad. Then hit them with the soldering iron to tin them, also. Then use a small amount of the paste at each joint to tack them all together. The thin piece of copper wire I would get from a section of multistrand wire, just 1 strand. After everything is in place cover the new trace up it a couple of coats of clear finger nail polish, to keep it in place and to ensure that it remains in place and can't short out.
I do this for a living. I have multiple soldering stations, with multiple tips for each of them. I have a stereo microscope that zooms to 90X to work under and inspect the work.
I have used the trace pen you refer to on a number of occasions for various things. I have even used it with the tape as I previously described to mend the flex cable on DS Lite upper screens. One of the main things you have to watch out for is the tip tends to dry out quickly. After the tip dries out the pen is useless. So you will need to get all your projects finished within a few days.
Was dit antwoord nuttig?
Score 3
Commentaar:
and what would you recommend or what do you use? I don't foresee this as being a one off use, I've been looking at this for a few projects in my "too hard basket", plenty of ideas!
door
Voeg je antwoord toe
pollytintop zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 1,271
