Ga door naar hoofdinhoud
The larger version of Samsung's flagship phone. Released March 2018.
129 Vragen Bekijk alle
No Network Connection/ No Signal At all! T_T
Hi..good morning.. I have this problem..they replaced my charging board with a new one because its not charging, and its charging again…the problem is…after they do the replacement..now the signal/network connection is gone. I’ve already did a factory reset hoping that its a software problem..but its still the same….the technician here said he dont know how to fix this..hopefully you guys can help me with this…thanks.
Is dit een goede vraag?
1 Opmerking:
I’ve also changed to different new sim cards, still no network connection/no signal. I tried all of these sim cards with my cousins phone and it works…I’m also at a place where there is a good network/signal coverage.
door
Voeg een opmerking toe
1 Antwoord
There may be a possibility that they used the wrong charge port. With samsung devices there are a few variants for charge ports, rear cameras, and antennas. If the wrong port is used, it usually leads to a “No Sim” message despite a sim card being installed. The next issue could be damage to the small antenna cables that go from the motherboard to the charging board assembly. Have them open it up and inspect those cables and ensure they used the correct port for your device.
Was dit antwoord nuttig?
Voeg je antwoord toe
Alexis Birog zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 603
