Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
In June 2017 Apple updated its 13" MacBook Air with a newer Broadwell Intel Core i5 processor, resulting in slightly increased performance and battery life.
271 Vragen Bekijk alle
Cant boot, how do I make a backup?
Few problems. Some updates was happening, but something went wrong. Now, after typing in my password its trying to load for some time, eventually ending up with a black screen with a white circle and a line (like a forbidden sign). So I cant boot up.
I have tried these steps :
  • Tried booting up on a external Mac test disc with catalina. I can see my internal SSD, but theres the normal one called MacHD that seems completely empty? Then theres also another partition/drive called Data, which seems to have some wierd files.
  • When i try to use First Aid on MacHD, nothing happens. But when i try and use First Aid on the Data disc, it seems encrypted and asks for a code i dont remember (its not the same code as i use to login with)
  • Is my SSD broken?
I’ve tried searching google for a Macbook Air 1466 SSD adapter to sata or USB. I can find one that pops up, but that shows it only works for the 1466 (2012) version, say what?
Update (02/18/2021)
@danj Last 3 questions :
  1. Where can I read that my A1466 (2017) SSD is compatible/the same as the 2015 SSD you mentioned earlier?
  2. If i get the adapter to work, is it even possible to copy over data from an encrypted SSD
  3. Is it possible to do a clean MacOS installation on a encrypted SSD ?
Is dit een goede vraag?
Commentaar:
Here's a listing which should help explain why I know your SSD is the same as the 2015 system MacBookAir7,2
As you can see all of these are using the same interface and If you review this great guide here The Ultimate Guide to Apple’s Proprietary SSDs under the Generation 4 section.
So I'm very sure the OWC case will work, and besides I've used it a few times to save a customers data from a dead system,
As for copying off encrypted data a file which is encrypted will stay encrypted! You would need to know the password to unlock the file.
If your drive is encrypted then its a question on which way you encrypted it. If you used FileVault2 you should have saved the FileVault recovery key to unlock the drive. Otherwise you'll need to speak with the application maker who's encryption you used.
Formatting the SSD will loose all of the data on it! If that is your intent then you should do a secure erase. Newer macOS releases hide this as its assumed you have encrypted the drive Secure-erasing your Mac’s disks is no longer secure, Apple says to make sure the data is not recoverable! But don't you want to save the data?
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
The 2017 system uses the same SSD as the 2015 model (both are MacBookAir7,2) and both are 8.0 GT/s PCIe x4 interfaces.
This is what I would use OWC Envoy Pro
OWC appears to be falling asleep at the switch here as they didn’t update the page.
Was dit antwoord nuttig?
Score 1
Commentaar:
Thanks for this.
Can you help me find something abit cheaper but still compatibable ?
door
@simon jensen - I don't know of any other solution. OWC is really all there is.
Keep in mind the limited market for this case. How many do you think would be sold? Not many ;-{
door
Hello Simon
Thanks for your question,
for your machine white has an pcie SSD you will meet an adaptor like this one here https://www.amazon.com/Adapter-Converter...
It comes with everything you need to backup the drive.
Try running Apple Diagnostics and comment if it says anything is wrong.
Hopefully this helps!
-Javen
@tacofixes
Commentaar:
Hey there., and thanks for the answer.
Im afraid, that is definately not the correct adapter. The pins doesnt match at all.
My S/N is : fvfvjt53j1wk
Macbook is this : A1466 (EMC 3178)
door
Sorry to hear that. Well off to google to find a proper Adapter
door
How about this one https://www.amazon.com/Convert-Adapter-U...
This should be compatible
door
@tacofixes - Nope! Neither of these adapters will work both are for M.2 blade SSD's. Apple did there own thing! There blade SSD's use a very different interface. Here's a great reference! The Ultimate Guide to Apple’s Proprietary SSDs
door
Regarding the two volumes that show up in Disk Utility, macOS Catalina introduced a new system volume which you can read about here. It sounds like the OS was damaged during the attempted software update. Since First Aid is not able to resolve the issue, I would recommend attempting to reinstall macOS. Here are some instructions to help you reinstall macOS on your computer. If you just need to backup your data you may need to boot into a bootable external drive running a similar version of macOS - from there you might be able to access the data on the internal drive. I hope this helps!
Voeg je antwoord toe
simon jensen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 29
