Plugged iPhone but reading 0 Ampere on USB Tester
I moved the parts of my iPhone to a new housing since the glass at the back was destroyed. Now, my iPhone is in a boot loop and I tried to put it into DFU mode and plug it to a computer, but iTunes and 3uTools does not see it. I tried to use my USB Tester to see if the iPhone charges and my tester reads 0 Ampere, but when I plug the charger, the iPhone would turn on. I also tried using multiple cables, and also tested the cables on other iPhones.
- What does this mean and how can I fix it?
- I didn’t plugged in the NFC / wireless charging coil yet, because the part did not arrive yet. Would this cause the issue?
Is dit een goede vraag?
1 Opmerking
I use this app to test my wireless and regular chargers, wires and battery - “Amperes - battery charge info” https://apps.apple.com/us/app/amperes-ba... It works great and even has the online benchmarking portal, where you can compare your tests with others.
door ALI
