MacBook Pro 15 Inch 2012 Charging but won't turn on
Hey guys,
So this is a weird one. I’ve read through numerous of related questions/answers and i feel like the GPU could be at fault here but I’m not sure at all.
So I was using the macbook perfectly fine without any issues and the battery was low, so before i could plug it in, it went to sleep, like always, and i plugged it in and closed the screen.
The next day, it was as if it was dead. Pressing the power button would light up the keyboard but nothing would come on in the screen.
So I tried running all the SMC/NVRAM reset commands and tried everything, even a power cycle after disconnecting the battery. Then the keyboard backlight also stopped turning on. When plugging in the charger, it charges. Turning on the machine, I can see the sleep light on and it turns off after a while. The battery indicator is also working.
Connecting an external display doesn’t work either.
Is there anything that could be done to revive this machine?
Thank You.
Is dit een goede vraag?
