Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Repair guides and support for LED, LCD, HD and other Vizio TVs.
790 Vragen Bekijk alle
How to identify which connector is positive and which is negative
Hi everyone,
I’m having an issue with D55un-e1 LED tv. LED driver/power supply is not working after using a multimeter. I wanted to check if it’s the backlights so I got an LED tester. However, the connector points do NOT indicate which connectors are positive and which are negative. (Power supply board : PLTVHU401XABV).
Here is the picture of the connectors
Could anyone please help me with where to stick my negative and the positive in this situation?
Thank you so much!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@johnny_k
Look on the board where the LED power cable plugs into.
the VLED leads are the +ve leads and the -VLED are the -ve leads
The pin count is shown on the board i.e. 1 down the bottom or on the right when looking at the image you posted and 12 at the top or the left.
So place tester between pins 12 (+ve) and pin 10 (-ve) ON THE PLUG, (which is disconnected from the socket)
Then between pin 11(+ve) and 9 (-ve), then presumably between pin 2 (+ve) and pin 8 (-ve) and then pin 1 (+ve) and pin 7 (-ve)
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Johnny K zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 16
