Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
1876 Vragen Bekijk alle
Can only hear calls on speaker
I just replaced the screen assembly in my iPhone 7 and everything is fine except you cant hear the calls unless its on speaker. I’ve read in here some things to do and try and nothings worked yet. My question is, any reason I can’t use the speaker from the old assembly, it worked fine. Any other suggestions welcome, thanks.
Is dit een goede vraag?
Voeg een opmerking toe
De essentiële toolkit
De meest behulpzame tools in onze meest compacte kit.
Koop nu
Koop nu
3 Antwoorden
Het nuttigste antwoord
Can Siri hear you? Sometimes the assembly can get damaged while transferring. Check the 4 contacts can make proper contact with the speaker.
If you cannot find the problem you will have to purchase another front camera assembly. If this still doesn’t work let us know.
Was dit antwoord nuttig?
Score 2
If I remember apple correctly, there are two separate speakers, one for the speakers, and one for calls on the top of the screen. Now with my Samsung I had a similar issue after changing the screen and I had failed to install it properly. I'm not sure it helps, but is there a chance you missed a step?
Score 1
Commentaar:
Very well possible :), but I don’t think so. I’ve done it several times me went over the guide and it mentions nothing about speaker. The camera works which is on that same connection.
door
Hey all thanks for your help! This led me to changing the speaker from the old assembly, I’m just assuming the speaker on the new assembly was bad. I tried to reseat it no change but the old speaker worked. Thanks!
Voeg je antwoord toe
Reggie Goldman zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 38
Afgelopen 30 dagen: 38
Altijd: 38
