Ga door naar hoofdinhoud
Released in November 2020, the 13" MacBook Air features Apple's Arm-based M1 SoC with an 8-core CPU and up to an 8-core GPU. (Model A2337 / EMC 3598 with two Thunderbolt 3 ports)
42 Vragen Bekijk alle
Is it possible to replace the battery of the M1 MacBook Air?
I have a new M1 MBA 2020 and am wondering if the battery is replaceable if it dies eventually after a few years?
Is dit een goede vraag?
Score 7
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Here’s a good writeup on the new M1 13” MacBook systems M1 MacBook Teardowns: Something Old, Something New
As we can see comparing the older Intel and the new Apple M1 models we can see the battery appears to be the same and like the older one also glued in!
Early 2020 13" Macbook Air
M1 13" Macbook Air
So I would say its very possible to replace it!
Was dit antwoord nuttig?
Score 2
Commentaar:
Hi,
indeed the battery is easy to replace. It´s glued as we know it already from iPhones e.g. If you are careful enough it´s no rocket science.
That’s why I choosed the MBA M1. It´s important for me to use this device for several years.
door
I have bought this laptop less than a year ago, and I have opened it up multiple times since. The battery should be easily replaceable. However, you should not need to replace it very soon as the M1 chip is very power efficient. My MacBook Air is still at 100% battery health after only six months. The charge cycle is also very low at only 52. Apple quotes that their laptop batteries can withstand 1000 charge cycles before they start to degrade. Also, Apple’s battery management is one of the best in the world and will keep your battery healthy for years to come before you even need to think about replacing it.
Score 2
Commentaar:
I think it's not that they start to degrade after 1000 charge cycles, but more to expecting to have around 80% battery capacity after around 1000 charge cycles. Just thought that I would point this out
door
mine just went to 97% after 82 cycle
door
mine ist at 91% after only 88 cycles
door
I have been concerned because my battery capacity has dropped much more quickly. At 11 months and only 59 cycles, my maximum capacity is at 90%.
door
I'm at 87% after a year. And it had dropped precipitously after just a few months after purchase. Not thrilled with that, but apparently Apple won't touch it unless it gets down to 80%. Fortunately, I don't run it on pure battery very often and for long periods of time, so it still is a great laptop with really good runtime.
door
Yes, the battery is replaceable with screws and street friendly adhesive. If you want to learn more about how to replace your battery, ifixit has a wonderful guide you can check out.
Score 1
Commentaar:
Does macOS perform any kind of software check that can reduce performance while installing a replacement third party battery on an M1 Air?
door
Voeg je antwoord toe
Francis Fry zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 31
Afgelopen 7 dagen: 187
Afgelopen 30 dagen: 832
Altijd: 11,069
