Ga door naar hoofdinhoud
Model A1502 / 2.4, 2.6, or 2.8 GHz dual-core Intel processor / Released October 2013
523 Vragen Bekijk alle
Battery not charging, magsafe orange battery detected
Hi.
I bought this MacBook on eBay, worked fine first couple of days. Then went to restart it last night and it would chime and turn off right away, happened a few times until I held the power button down until Apple logo came up.
When booted, connected charger but it would detect the battery and not charge. I had 32% battery power. Now it's on 18%, once it's dead I won't be able to do anything
MacBook also running slower than normal, did not happen when I got it.
Reset SMC/PRAM and no luck. Tried swapping out DC board, magsafe port, battery from another similar MacBook, same issue. It's the logic board.
I'm sure it charged when I got it, done nothing to it except put it on and update to MacOS Sur. Now this issue. Seller refusing to accept a fault. I don't know history of whether water damaged previously.
What can I check to fix this on logic board please?
Ran diagnostics got PPP003 error.
Pictures from coconut battery attached:
Logic board
Is dit een goede vraag?
Commentaar:
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Voeg afbeeldingen toe aan een bestaande vraag
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Well, you’ve got a few problems here!
First the battery is on its last legs as its close to the end of its expected life of 1,000 cycles. Some batteries don’t make it to the 1,000 so its possible its running on vapors now!
The charging logic and your MagSafe charger are not working properly! As CoconutBattery is telling us the charger is connected the charger its self is not charging the battery which is should be given the batteries current state of 17.4% charged Charging with 0 Watts!
At this point you’ll need to look for corrosion around the SMC logic. Follow this guide to take it out MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement and inspect both sides for any spillage or corrosion or any damaged components. Make sure the sky blue area which is the SMC chip and its supporting logic is all clean on the backside of the logic board.
Update (12/28/2020)
Well I can’t see any signs either, so that leaves only one thing left a knockoff charger which has damaged the voltage comparator resistors! Here’s a good explanation from Louis Rossmann How cheap eBay batteries DESTROY Macbook logic boards! While Louis is describing the Unibody MacBook Pro’s SMC the same logic is used in the Retina models (its laid out a bit differently)
At this point its time to visit someone with the deeper skills to fix your logic board.
Here’s some additional info:
Don't Replace Your MacBook Charger With a Cheap Knockoff
OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth
Lacking safety features, cheap MacBook chargers create big sparks
FAKE Magsafe MacBook Chargers on eBay - Watch before buying a Mac Charger
Sadly, it is very hard to tell which is which from the outside. We used a scale to measure the weight as the best way. Using a known knockoff which is lighter in weight to compare with the others we had. We had hundreds to check!
Make sure you bought your charger directly from Apple and its in its original packaging.
Was dit antwoord nuttig?
Commentaar:
Hi Dan.
Thanks for your response. I have tried the same battery with another logic board and it charges and shows good status. Tried the same MacBook charger on another and it charges well.
I have attached pictures of the logic board and inspected against the areas shown and there appears no physical or corrosive damage I can see.
door
Thanks @danj. I've watched that video before as I also suspected a similar issue. However I did not use a fake charger. I never use one that isn't Apple. Maybe though before I bought it the seller did, but what's strange is that battery was fully charged when I got it. So he must have charged it somehow.
Anyways, as you say more deeper diagnostics needed on the board. I'll get it checked out.
door
Voeg je antwoord toe
Faisal Gondal zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 41
Altijd: 377
