Ga door naar hoofdinhoud
Repair guides and support for smaller headsets that rest on top of the ear, also known as supra-aural headphones.
60 Vragen Bekijk alle
Bluetooth function wont work, or turn on so I have to use wired.
So I got these synchros s400 bt and for some reason when I go to charge the light around the port goes red and stays red. I dont know what's wrong.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @spongebobsquare ,
I think that the battery may be failing and needs to be replaced. Even rechargeable batteries have a lifespan
I cannot find a teardown or battery replacement guide or video for the headphones but here’s a video that may be of some help. At approximately 1:22 minutes into the video the battery can be seen.
Replacement batteries are available online. Just search for JBL Synchros S400BT battery to get results for suppliers that suit you.
Was dit antwoord nuttig?
Voeg je antwoord toe
Van zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 29
