New battery fitted but not charging
MacBook Pro Early 2015 13”
New battery fitted by a local technician. I had to take it back as he seemed to have messed up the keyboard (w-o characters weren’t working). He fixed at his cost. Get laptop home for the second time. It has some charge and is able to function, I think, without the cable. So I try to fully charge it but it won’t go past 30%. Then I realise every time I unplug it switches off. Battery icon says it isn’t charging. I’ve tried resetting smc but this hasn’t worked.
. I will take it back to the guy but I am somewhat worried that he is going to make up an excuse to say that the laptop is faulty and it isn’t his responsibility. Any help much appreciated. TIA.
Is dit een goede vraag?
What is the color of the MagSafe charger LED? Amber or Green, bright or dim?
door Dan
Hi - It’s Green before I login, once logged in it becomes Amber. Bright in both cases
door Andrew B
@macondo - OK, let's let it charge over night (good 6 hours) when you see the Amber LED. Did it finally go Green? Did CoconutBattery show an improvement?
door Dan
Ok will do. Thanks.
door Andrew B
It had 7 hours. Amber LED stayed amber. No improvement shown on Coconut battery :(
door Andrew B
1 commentaar meer tonen
