Ga door naar hoofdinhoud
Model A2159, EMC 3301. A refresh of the entry-level 13" MacBook Pro. Available in Silver and Space Gray. Released July 2019.
112 Vragen Bekijk alle
How do I open and permanently disable the camera?
Hi, anyone know how I can permanently disable the front camera? is there a way to open the macbook and snip the camera cable?
Update (11/25/2020)
It’s for my young daughter so I would prefer to disable it completely, is there no way at all to do this?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
The best answer is to just use black tape over the lens!
Think of it this way…
You have a can of peas! All you want is to take out a spoonful, now what do you do? You can’t reseal the can and the quantity is now different! To add it it in a few days what’s left will have spoiled.
Apple designed the system and the display assembly in such a way you can’t physically disconnect the camera internally without damaging the system as well as the display its self.
Update (11/25/2020)
Apple offers a system management app which companies use to manage their gear or you could create an admin account you use to control your daughters system, Limiting her account so she can’t alter things (apps or OS).
Then using Terminal remove the camera resource from the system. WARNING I haven’t done this in quite a few years so I’m not sure is the newerMac’s and macOS’s will respond nicely.
Disabling the Hardware of the Camera:
Through this method, the hardware is completely disabled, which means that you won’t be able to use the camera for any purpose. No application, whether built-in or 3rd party would be able to access the camera until you reverse the process.
  1. In this step, we will create a backup of the file. Open the terminal and type in the following command. Remember that you can skip this step if you don’t want a backup created. But it is advisable to keep a backup so that you can reverse the process in case you want to use the camera again.
    1. mkdir /System/Library/QuickTime/ .iSightBackup
  2. It’s now time to move the Quick Time component of the iSight camera (which enables apps to access it) to the backup folder we created in step 1. Use the following commands:
    1. sudo mv /System/Library/QuickTime/QuickTimeUSBVDCDigitizer.component
    2. sudo mv /System/Library/QuickTime/ .SightBackup/
  3. Reboot and you are done!
  4. In case you want to use the camera again, just put the file QuickTimeUSBVDCDIgitizer.component in the following directory /system/library/QuickTime and reboot.
Was dit antwoord nuttig?
Score 3
3 opmerkingen:
Similar issue with my FHD Touch E7440 - display is built in such a way I can't remove it without damage (easily). Yet I can physically do it on my E6440 because it's non-touch. I'm not a fan of touchscreen laptops, but I got a deal on them despite the Covid shortage because they were non boot - both came back, but I had to buy a new screen for one due to backlight issues.
I'm putting tape on the cam backed with wall-safe Scotch tape on. I hate internal webcams, but sadly the majority voted with their wallet and got them in anything that isn't designed with CTO in mind. With used, you're stuck or you're forced to choose specs or no cam - I chose specs>no cam because I'll probably never get a chance to negotiate it down as far as I did anytime soon - especially with remote learning.
door
@danj You may need to disable SIP these days - I don't think the SIP MacOS releases will take as well.
ABM is probably out of OP's budget, especially for a parent wanting to block the cam. Admin/Standard account may be the way to go. I don't know if Apple would do the ABM sale or not.
I ended up breaking my approach on this into it's own answer, mostly out of necessity.
door
Is this method still compatible with the latest Mac OS ?
door
In terms of anything physical, none of them work well on Macs these days as they're not a way to open the screen and the webcam cable is integrated into the display cable on Macs, it's not split. The older ones could be done but they require a heat gun and it's hard to reverse. I wouldn't recommend tamper-evident tape or a cover on the display directly either since it may damage the AG coating and covers tend to break it these days. Your best bet is to see if there's 3rd party software that can block it, or if you can use Screentime.
Your needs may be better served with a used PC, like an older business notebook. On many of these, the cam can be left installed with a BIOS block (disabled in BIOS and doesn’t show in Windows) or you can physically disconnect it since most PCs are more friendly to such a thing. It’s the nightmares like my FHD Touch E7440 you need to watch for - it’s built in such a way I can’t take it apart without ruining a $120+ USED assembly easily. If you do not want to deal with it being present at all, you can sometimes choose lower spec models like my E6440 pre-display assembly swap (i5-4300M/4GB RAM/768p TN LVDS LCD) and they usually do not come with it, or look for a surplus unit that lacks a camera; though take note it's probably government or business surplus and was treated as such. Most manufacturers dropped the webcam delete option for consumers years ago. Covid note: A lot of these are more ready than sometimes nicer “high-risk” machines. It's not easy to find one that’s ready to use due to higher demand form parents.
Example of what to look for:
AVOID (IPS; panel looks really good, but the design makes camera removal difficult):
GOOD (poorer quality LCD, but easy to remove without damage):
However, be careful about displays - when I got mine, the display was bad (I got it cheap because of that). In my case, I found a HD+ (900p) webcam assembly was an extra $4 because of cosmetic damage I can live with for a better panel without having to muck with the cable. Yes, the E6440 LVDS has different cables, while the iDP has one (iDP has better panel upgrade viability). However, it is a horrible machine if she needs to carry it (thicc+~4.5lbs).
CAUTION: On the business machines, you need to be a little careful about Computrace being active. If it is, check with Absolute SW and provide your proof of purchase and they’ll help you remove the tracking from the machine, but nobody can change the persistence module - not even Computrace. But it can be “neutered” with a POP and an eMail.
In terms of the cut: Don't cut it - it makes restoration hard for you to reverse, or if someone buys it secondhand hard for them. Disconnection or removal is usually sufficient, especially for someone who isn’t there technically. Cutting it devalues the hardware to tinkerers. I personally hate machines someone ripped the cam out AND cut the cable. If I'm dumping the assembly (or at least the back lid), I’m still annoyed but I consider it neutral because it never mattered. The issue is if it's in nice shape and I do not need to replace the back lid, I'm looking at a 1-2 hour repair to reverse someone else's heavy-handed parenting. If possible, disconnect the module but leave it in the notebook so it can be quickly reversed so you can also go back when she's older.
Score 1
Voeg je antwoord toe
Dan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 48
Altijd: 1,364
