Ga door naar hoofdinhoud
Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
167 Vragen Bekijk alle
Replace the Logic Board after power cable is stuck in port?
I'm trying to repair my neighbor's 2001 iBook. The end of the power supply connector has been stuck in the laptop for almost 9 years! I read the iFixit manual on how to take-apart the lower case to access to power supply port. I was able to pry out the connector out of the port with tweezers and electrician's dental picks. I separated the port from the logic board by accident. Do I have to replace the entire logic board or the power supply section of the logic board?
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Score 1
Een opmerking toevoegen
MacBook-reparatiesets voor batterijen
Vanaf $69.99
Buy Now
Vanaf $69.99
Buy Now
1 Antwoord
Gekozen oplossing
Hi! It depends on what you mean by "separated the port from the logic board", but it sounds likely you just need a new DC-in:
iBook G3 12" DC-In Board
The DC-in is not actually part of the logic board itself, but a removable module. If the port has come off of the "logic board"-like part of the DC-in, then you should just be able to replace the DC-in. If that doesn't look like what you need to repair the machine, let me know.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
dadocta4880 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 1,057
