Ga door naar hoofdinhoud
2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
20 Vragen Bekijk alle
Why won't my MacBook boot up.
I have a 15 inch non unibody MacBook pro that won’t turn on. It originally turned on when I got it last year no problem. Then it started to take longer and before harder to turn it on. I recently took it out of storage to turn it on and can’t get anything out of it. Last time i had to do something with the ram when it was plugged in to turn it in. Is it the pram battery?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Yes its possible your pram battery failed, also make sure your ram you put in was compatible( 667mhz ddr2 pc 5300 or 667 MHz DDR2 SDRAM). Try a pram reset or smc to see if it comes back on.
Hope it works,
Was dit antwoord nuttig?
Voeg je antwoord toe
Owen Hewitt zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 88
