iPhone 8 has a black screen
Hi I have a iPhone 8 and the screen display is black does replacing the screen/display or battery fix the black screen
Is dit een goede vraag?
Replacing the screen should fix it unless there is an underlying issue. I would buy a cheap replacement and test it to see if it works. Good luck!
Was dit antwoord nuttig?
Sounds like a screen issue, I presume the phone is on, you just can’t see the screen…. in this case you should go for the repair.
Richard
Technician
Thank you for contributing to the Answers Forum. However, the site owners don't want folks linking/advertising their services directly in answers or comments. It is advised that you put your contact and business offerings in your profile and link people back to it.
The moderators thank you!
The reasons why iPhone black screen of death are various. Here I list some reasons and methods to fix it.
You can change a battery or charge your iPhone for a while and then check if it can turn on normally.
You might have tried to restart your iPhone and it failed. You can try a force restart to fix it. The ways to force start iPhone are different from other versions. How to force restart iPhone of different version can refer to: Force restart iPhone Apple.
It is very likely that there is something wrong with iOS and it needs to be repaired with a powerful iOS repair tool. iSunshare iOS Repair Genius is highly recommended. It can help you safely and efficiently fix most of common iOS problems without data loss.
You can restore your iPhone to factory setting with iTunes. But it will erase all the data on your iPhone. So, you’d better back it up in advance. Details can refer to: Restore your iPhone, iPad, or iPod to factory settings.
I hope these methods are workable for you! GOOOOD LUCK!
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 163
This question was migrated from https://meta.ifixit.com/Answers.
door iRobot
