Ga door naar hoofdinhoud
Larger version of the Nintendo DSi, released March 2010 in North America. Most repairs are accomplished with only a screwdriver and prying tools.
149 Vragen Bekijk alle
dsi xl charge port ripped pads
so i tried to repair my dsi xl because it had a bad charge port, and i had bought a replacement charge port but when i went to try and take out the faulty charge port, i had ripped 4 pads out if the motherboard. the pads where the 4 pads all next to each other. and yes i have solder experience but this was my first time replacing the port
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Hi, sorry i come almost three years after the "war". Don’t worry about judgment here, all the people who try to change a port of a ds know the complexity of changing it (and I’m not saying that because I’ve already changed at least 30 ports and I still sometimes brought pads!^^ ). There is still a way to save this motherboard, if in the three years she was not finished in the trash or in donor board, just put a "'jumper wire" you have to solder to the part of the port that no longer have a pad, follow the line of the pcb and remove the green protect on the pcb to be able to solder the cable and do it for the four, here is a video that will explain better than me and shows how to do (not on a ds but that explain the process) https://www.youtube.com/watch?v=AR0lb7YI...
Was dit antwoord nuttig?
Voeg je antwoord toe
Eduardo Bustamante zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 22
