iPhone 11 pro not included
Hello, the phone is obviously dropped and does not turn on. what is its problem circuit board or battery.
Is dit een goede vraag?
If you did have vibrate on mute enabled, you can perform a quick and easy test. Simply flip the mute switch. If it vibrates then its obviously not the battery because it is powered on. You could also try to call your number. If it rings then again, it’s powered on. If you dropped it you most likely damaged the OLED panel.
Was dit antwoord nuttig?
Thanks for the info will work. ;)
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 258
2 opmerkingen
have you tried a replacement screen at all?
door Jade Richards
I'm not I thought it was the battery
door dimit1r89
