Ga door naar hoofdinhoud
Repair guides and support for small electric personal space heaters.
Why is my new dimplex 240 volt wall insert heater not working
I have a dimplex electric 240 volt wall heater and when I connect it it shows over heat and the red light comes on even though the heater hasn’t even run? your help is appreciated.
Is dit een goede vraag?
3 opmerkingen
The brand of my heater is a 240 volt 1500 watt dimplex wall heater not the Royal Heat brand
door
Hi
What is the model number of the heater?
door
My model is T23WH1531CW
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @gbreed ,
Has it ever worked properly?
Have you connected the 240V AC power feed correctly? (Do you need to have 2 x 120V AC where you are to achieve 240V AC?)
It may be a faulty temperature sensor but this would have to be checked.
Since you say that it is “new”, according to the warranty (scroll down and click on the Warranty link - right side of page) there is a 2 year warranty on the unit. I suggest that you contact the manufacturer’s customer service section about a warranty repair and don’t void the warranty by trying to fix it yourself. That’s what warranties are for ;-)
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Brent zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 377
