Ga door naar hoofdinhoud
home screen touch controls , volume , back and home not on screen
home screen touch controls , home , previous , multitasking and volume not on screen
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Hi,
With the tablet turned on, use a straightened paperclip to press and hold the recessed reset button in the tablet for about 5 seconds, then release and check if this restores the screen controls. The tablet will shutdown and then restart once the button is released
Here’s an image to show where it is located.
(click on image to enlarge for better viewing).
If that didn’t work try a factory reset.
Be aware that a factory reset will erase all your data and downloaded apps. It will restore the tablet to its factory default condition. Backup your data to the cloud or a computer before performing the factory reset. You will also have to remember the tablet’s Google account User ID and password (if one has been entered into the tablet) so that you can re-enter it to access the tablet after it has been reset, otherwise you will be locked out
To reset the tablet open Settings from the application menu, then tap Privacy > Factory data reset, click Reset tablet and then Erase everything to format your tablet.
Was dit antwoord nuttig?
Voeg je antwoord toe
dpaul_51 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 140
