Why is my audio crackling sound after 30 minutes?
Sound starts to crackle on audio out after 30 minutes. If I switch to optical out it works better but still occurs. I have eliminated the Nvidia Shield as the source by trying another shield; And it works over Bluetooth to my sound bar save the shield disconnects after 35 minutes. I am using hdmi and have try both sources. I haven't try composite in yet. Which part could it be? Any suggestions on how to ‘fixit’.
Is dit een goede vraag?
3 opmerkingen
Hi,
What is the model number of the TV?
You said that you tried another Shield, did you try another HDMI cable as well? Also you said "I am using hdmi and have try both sources" does this mean different HDMI inputs on the TV?
To eliminate it further you may have to try the Composite connection, as Composite audio is an analogue signal which doesn't use the digital signal processor on the mainboard in the TV, whereas HDMI is a digital signal which does.
Does the TV have the latest firmware installed?
door jayeff
Jayeff:
I hope you are having a fine week.
Thank you very much for you very helpful response. It is very much appreciated.
No I had not been able to test the composite in. I was planning on testing that but it required setting up a composite in source. I did try several hdmi cables prior to switching from the 1/4 inch audio out to the optical cable. I thought the optical cable had fixed the problem but it only delayed the crackle for a longer time. Also with the optical cable the crackle was not as pronounced so we could actually still use it some what.
Yes I was referring to the hdmi input sources on the TV. Sorry for the confusion, I wrote that post on my phone while sitting in my car during a blackout the other night: (Man that was brutal loss by the daboy's monday night.)
No I haven't updated the TV firmware recently. I probably should do that but I don't use the smart features and I believe the wi-fi is disabled.
door Mark Lane
The model is one of the Samsung 58" 1080p 60Hz/120CMR LED Smart TVs, I am not sure the model number at this second; I would go checkout the model number but it turns out that the TV was not at fault but there seemed to be some issue with google play music.
door Mark Lane
