Is my technique wrong? Can't remove anything from motherboard?
Hi!
So I have a really frustrating matter. I cant seem to remove any chips or anything from a nintendp switch board ive used all kinds of different flux including Amtech and rework stations my previous rework station was cheap and terrible so I bought a new upgraded alot more expensive and when I used it fir first time with some cheap flux I was able to remove the m92t36 for the first time ever since then I've not beenabke to remove anything.
I paid like 30 pound for some amtech assuming my flux had gone bad ive even messed around with the temperate by increasing it higher as well as the airflow but it doesn't seem to remove anything other than burn my board and cause smoking!!
Any suggestions please is my technique all wrong?
Is dit een goede vraag?
3 opmerkingen
@katrinaxox what temps are you using and do you even get the solder to liquify. Are you using hot air alone or are you using your soldering iron. Did you tin your tip before trying to desolder any components? Have you tried a solder wick with flux on this yet (not IC's but other components)?
door oldturkey03
Great comments and questions @oldturkey03 !
door Minho
@refectio Hi! Is there way you can help at all with this regarding everything I've said I can personal message or call you to show you what I'm doing im more than wiling to pay you for your time I dont expect you to help me for free.
Just would really love some guidance to get components off the board as when I'm trying different fluxes as well as changing the temperature and air flow on the machine and still nothing is working it can be quite confusing and frustrating.
door Katrina Whattam
