Ga door naar hoofdinhoud
Announced in August 2017, the Galaxy Note8 is the successor to the recalled Galaxy Note7. The Note8 was made available to the public for purchase in September of 2017.
147 Vragen Bekijk alle
Electronic cleaner on my iris scanner / front camera damaged them?
So my front camera had a smudge on it and I decided to spray electronic cleaner on that and the iris scanner. Now when I open the camera app I get “you cannot use more than one application that uses the camera”. I’m ordering a new iris scanner & front camera, but why would electronic cleaner damage it? I thought it was safe on electronic parts like this.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi @monist ,
All liquids except distilled water conduct electricity to some degree.
What are the listed ingredients of the liquid cleaner that you used?
Usually Isopropyl Alcohol 99%+ (available at electronics parts stores) is recommended. Although it also is still conductive when wet, it evaporates quickly and leaves no residues, conductive or otherwise, whereas other cleaners may have additives etc and may leave residues and are not as effective
The idea with liquid electronic cleaners is that the power is disconnected or removed from the device before cleaning.
Unfortunately this is difficult with most modern mobile phones as the battery is hard to easily access. Also switching off the device may not help either as the power button is not a power isolating switch merely a momentary switch that signals the CPU on the systemboard as to what to do. There is always power available at some points on the systemboard even when the phone is “off”. Think of the phone being in an extremely low power state rather than being totally switched off and isolated from the power supply i.e. battery.
Usually you can get away with cleaning with a spray as long as the liquid is not liberally sprayed onto the device. Spray it on a clean, lint free cloth so the cloth is just damp, not dripping and then wipe small areas and allow to evaporate before repeating if necessary and moving on.
A lot of phones are only water resistant and not waterproof but again this is when they left the factory and perhaps not after they have been used for a while. My personal view is that accidentally dropping the phone more than once or twice or leaving a phone in the back pocket of jeans can’t be doing the frame much good, as far as the integrity of the case’s water resistance is concerned, i.e. cracking or bending it slightly through sitting on it or leaning against things with it located there
Was dit antwoord nuttig?
Score 2
Het nuttigste antwoord
Hello Aaron
If this type of liquid contains some substances that can damage plastic or rubber, this will damage a part of your camera. These types of cleaners are made to clean only the motherboard or similar components. But the cameras, microphone, speaker ... have plastic components that cleaners can damage.
I also agree with the sage Jayeff, in this case it could be a mixture of reasons for this problem.
Good luck!
Score 3
Voeg je antwoord toe
Aaron Ortega zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 64
