Magsafe gives a green light but the battery is no longer charged
In the past I changed the battery and everything went well.
Now, the magsafe gives a green light but the battery doesn’t charge.
I tried every reset procedure (i.e. SMC reset) but with no luck.
Is it worth to try to replace the DC-in Power Board ?
Is dit een goede vraag?
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Voeg afbeeldingen toe aan een bestaande vraag
door Dan
What? I really doubt this MacBook model has a charger with a light... or a Magsafe port.
Have you tried reconnecting the original battery to check if it's a battery issue?
door amatsuda
@ngs765 - Don't get in a twist! Clearly he selected the wrong system. Getting the CoconutBattery info would have given us the system ID to double check things.
door Dan
Now the screen is black with the red image of the battery that needs power…
No way to get it switched on
(yes, I selected the wrong system. Now I corrected it)
door Giuseppe Foderaro
