Ga door naar hoofdinhoud
2.6 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.2 GHz) with 3 MB shared L3 cache. Released February 13, 2013.
What is up with my Display?
Guys this is what happened to my Macbook Pro and I was wondering if anyone knows what is the best solution
1) Opened Macbook one morning after making some coffee and the screen was white with a gray halo around it… it was just frozen there.
2) I restarted the Mac and the screen was now totally black. I plugged it into my external Asus Display and found the laptop itself to be functioning properly!! apart from display
3) I went into system preferences “display” and it wont even identify the macbook monitor only the external one
4) Webcam works fine and even lights up when it is on
5) The Back apple light is always off
6) I have tried all software resets and nothing works so this is defo a hardware issue
How can I for sure fix this problem? What should I order and do?
Is dit een goede vraag?
2 opmerkingen
Aim a flash light in through the lids Apple Logo, do you see a faint image of your desktop and its icons?
door
Hi Dan. There is no faint images at all. In system preferences it won't even recognise the display.
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
This looks like the same issue: MacBook Pro won't detect internal display
Was dit antwoord nuttig?
Score 1
@luiz.pinheiro83 - At this point you’ll need to pop the bottom cover and inspect the internal display connection to see if it’s damaged if not you’ll need a new display assembly.
Follow thins guide to Step 9 MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement then jump down to Step 14 inspect the connection thoroughly.
Sadly, If you don’t see any then you’ll need to get a new display assembly.
Voeg je antwoord toe
luiz.pinheiro83 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 106
