Ga door naar hoofdinhoud
A wide range of repair guides and support for the consumer-grade laptop computer line by Toshiba.
967 Vragen Bekijk alle
Hello, my toshiba satellite laptop recently started not charging
Recently it started showing on the screen that …your battery is very low, please plug in …this flashes across the screen while it is plugged in. i tried removing the battery, to check o see if it was the adapter, but it wasnt. I left it to charge overnight and the issue still continued until the battery life depleted completely. Now i have to keep it plugged in use it. Is it wise to remove my battery and use the laptop without it? What exactly is wrong, is it the battery that now needs to be changed?
Also, the brightness keep increasing and decreasing even though i placed it at a set percentage. I would really appreciate any assistance as i am now doing classes online and this is my only laptop.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
In this case, I would remove the battery and run without it for the time being - not ideal, but it’s better then nothing. These kinds of issues are usually due to Windows power management misbehaving due to a worn out battery triggering the low battery display dimming. In other cases, one or more of the cells in the pack failed and the computer is trying to cope because the BMS didn’t blow a fuse or trigger a failure flag on and kill the pack. It sounds like the pack was on the way out for a while and you finished it off last night by charging it for the last time.
What can sometimes happen is a tired battery that is no longer usable (but has no bad cells) will screw with the Windows power management if it’s really worn out. This can happen on machines with a BIOS that isn’t coded well enough to ignore bad packs at the firmware level if the BMS hasn’t thrown the failure bit, which shuts it down at the pack level. IF one of the cells is bad and the permanent failure bit in the BMS IC doesn’t trip, that can also cause a similar issue - especially poorly coded BIOSes.
As an example when you see more sensitive failure bit triggering cases, it’s usually on Dell laptops (and the more sensitive BIOS). The Dell BIOS is not fault tolerant like others. While Dell is the most sensitive to pack problems due to their level of PR damage from the 2005-2008 Sony battery recall, you will still see these kinds of “sensitive” battery issues more often with the prominent 3 (Dell, Lenovo, HP) because it’s more of a PR nightmare for them. It makes troubleshooting easy because if you know the patterns and BIOS language you’re done in a few minutes, but makes life hard for people like you who aren’t aware of the touchy brands (like Dell) and plan ahead.
I have an older laptop here that never shipped with Windows 10 (most shipped with 7 - Latitude E6440 i5-4300M/HD 4600) which shipped with a mediocre battery when I purchased it (54% validated health). Despite the rough health, I’ve never had an issue with my display flickering. I’ve never had an issue with power management even at 27% health 5 months later, but it shipped with the NX31D pack. I know it’s a matter of time but I’m keeping it in use until it’s no longer usable. I’ve also seen it jump up, which is why I’m waiting (Ex: 27%->40%). The problem is once the NX31D (or anything with Samsung SDI cells) jumps like that, the end is coming. The best I can do is delay it by watching the capacity, recalibrating more often then once a month (likely 2 times/month) so I have enough lead time.
Was dit antwoord nuttig?
Score 2
@layla13 all of this “Now i have to keep it plugged in use it. “ leads me to suggest that this is all caused by a bad battery. Yes, you can use your laptop on the AC power supply but kind of takes the mobility away. Eventually you do want to change the battery. The brightness issue of the screen may also be related to the battery (power demand not being matched etc.) and re-evaluate this once you’ve changed the battery.
Score 1
1 Opmerking:
When it comes to the display dimming on Windows 10, it's usually due to the software power management rather then hardware power demands. What may be happening is actually due to the battery screwing with Windows power management.
door
Voeg je antwoord toe
Lia Bent zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 697
