Ga door naar hoofdinhoud
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Vragen Bekijk alle
What's the most battery charge cycle counts you've seen?
I’ve just bought an A1278 off eBay that has 3682 charge cycles on the battery, which is roughly double the maximum I’ve ever seen on one of these.
I know Apple says that they’re good for 1000 cycles, but wondered if anyone else had seen such an outlier?
Is dit een goede vraag?
1 Opmerking:
You mean two times and then some!
door
Voeg een opmerking toe
1 Antwoord
Time for a new battery for sure! MacBook Unibody (A1278) Battery
It probability dies in less than 30 mins when you disconnect the charger.
MacBook Unibody (A1278) Battery Afbeelding
Product
$99.99
Was dit antwoord nuttig?
3 opmerkingen:
Surprisingly not - I've had it on for the last couple of hours, it's actually genuinely in good health!
door
Even still I would replace it soon! You are treading on thin ice here. The Design cap is just above 50%, your charging logic is likely running hard and the system is also likely running warm (battery & logic board)
door
I'd be replacing it anyway, as I'll be selling it at some point soon. I'd not thought about the charging system on the board also running warm, so thanks for that insight Dan.
door
Voeg je antwoord toe
alasdair Sim zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 75
