Vertical Lines Across Upper Diagonal of Screen - Can I Fix?
I dropped my MacBook Pro 11,5 (Retina 15 in, Mid 2015) and now it has mostly vertical lines in the upper LH side. The monitor glass doesn’t appear to be cracked (by running my fingernail across it) but there’s definitely a diagonal line where the upper LH side is unreadable, and the lower RH side normal. If I twist the screen, I can partially read what is in the upper LH side. The computer appears to work fine in the Lower Right Hand side. Can I fix this? Thanks in advance. Eric
Is dit een goede vraag?
