Ga door naar hoofdinhoud
A 64.52" LED 2160p 4K UHD Television released in 2015.
11 Vragen Bekijk alle
Vizio P65-C1 extreme brightness issue
This morning I powered on my P65-C1 and the screen was incredibly bright. By bright I mean almost white. We had made no changes to any settings. I tried adjusting brightness and backlight and no change. It’s just plain ‘white’. I’m used to TVs eventually dimming, not the reverse.
I’ve done some research but can’t find any references to this specific issue. I’m not adverse to trying some repairs rather than having to replace it, it’s only a few years old! TVs sure are what they used to be!
Can anyone suggest next steps? I’ve tried factory resets, everything it just stays white. Could this need a motherboard replacement?
Is dit een goede vraag?
Score 1
1 Opmerking:
@jostewcrew Thanks very much! Apparently you understand ‘Mom speak’ better than Google! Will check it out!
door
Voeg een opmerking toe
1 Antwoord
@momof4boys … From your image, this isnt caused by your backlights. This is what is known as whitewash. This is caused by a faulty tcon board. You can google the symptom and images via google/youtube. here is one for reference:
https://www.youtube.com/watch?v=OvpZyYfd...
Changing your tcon board will solve your issue. You can google your model number along with tcon replacement and find a vendor online. Here is one from a vendor i use often:
https://www.tvpartstoday.com/55-65T40-C0...
hope this helps, post back with success update or any questions you may have.
Was dit antwoord nuttig?
Voeg je antwoord toe
Tanya Barton zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 124
