Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
The April 2014 update of Apple's 13" MacBook Air features refreshed dual-core i5 and i7 processors, plus slightly increased battery performance.
246 Vragen Bekijk alle
Laptop Dies When Unplugged
Hello all, first time here.
Recently inherited this MacBook from my dad who hasn’t used it in a year. The battery does not keep a charge and the laptop can only run on the power adapter. The MagSafe stays a constant orange. I have reset the PRAM and SMC and ran the hardware diagnostics which says everything is normal. Power report is as follows:
Battery Information:
  • Model Information:
    • Serial Number: C0142270EFVF90MA5
    • Manufacturer: DP
    • Device Name: bq20z451
    • Pack Lot Code: 0
    • PCB Lot Code: 0
    • Firmware Version: 511
    • Hardware Revision: 000a
    • Cell Revision: 1200
  • Charge Information:
    • Charge Remaining (mAh): 839
    • Fully Charged: No
    • Charging: No
    • Full Charge Capacity (mAh): 6018
  • Health Information:
    • Cycle Count: 105
    • Condition: Normal
    • Battery Installed: Yes
    • Amperage (mA): 11
    • Voltage (mV): 7395
It seems like the cycle count of 105 is well within its expected lifetime but I suspect the year with no use could have destroyed the battery. Anyways. not sure why there is a small amperage but it says it is not charging at all. I would bring the laptop to the Genius Bar or a service center but few places are open with COVID19 right now.
I’m willing to replace the battery myself if it seems that is the solution.
Thank you in advance for any guidance.
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Voeg een opmerking toe
Nintendo Switch-kits
Een snelle oplossing die je weer mee laat doen
Koop Switchkits
Koop Switchkits
2 Antwoorden
Gekozen oplossing
Yes you need a new battery, here’s the needed part MacBook Air 13" (Late 2010-2017) Replacement Battery and here’s the guide MacBook Air 13" Early 2014 Battery Replacement
MacBook Air 13" (Late 2010-2017) Replacement Battery Afbeelding
Product
$84,99
Was dit antwoord nuttig?
Score 1
Commentaar:
Thank you! Just finished charging the battery after the install and I'm following the calibration steps! Everything looking good.
door
Het nuttigste antwoord
you need a new battery.
Score 1
Commentaar:
probably need a new battery
door
Voeg je antwoord toe
mbelle zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 39
Altijd: 39
