Ga door naar hoofdinhoud
These repair guides are for a 2007-2012 Jeep Wrangler (JK) Sport, Sahara, Rubicon and Unlimited Editions.
23 Vragen Bekijk alle
runs for about 15 minutes then stalls?
My 07 jeep wrangler had the fuel pump replaced.
But runs for about 15 minutes then stalls?
I let it set for 5 minutes then it starts?
Will some times will run for a hour then stalls?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
THANKS.
The shop said it's the crank sensor..
We will see if that's it ??
Was dit antwoord nuttig?
I think there might be multiple problems, but mostly it should just be timing or some issues with the computer, because i have a skoda superb that had it’s computer replaced because of a similar problem, or you can also try to check your wiring
Voeg je antwoord toe
Gary Tennent zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 28
Altijd: 230
