Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
4-inch iPhone released in March 2016 with similar hardware specifications to the 6s. Available in Silver, Space Grey, Gold, or Rose Gold with 16/64 GB storage options. Model A1662 and A1723.
846 Vragen Bekijk alle
Battery had a small fire, can it catch fire again?
I was replacing the battery in an iphone se and the pull tabs broke so I attempted to pry the battery out, at one point the battery started smoking and a small fire happened for probably 3 seconds. The battery was almost fully dead at the time of removal. Is it safe to continue to pry it out and can it catch fire again?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
In my experience if they catch on fire it is only once. Take it out side and finish removing to be safe.
Was dit antwoord nuttig?
Score 4
Commentaar:
Agreed! A Damaged battery is too dangerous to leave in and you want to place the phone some where if it were to catch on fire it won't start a bigger fire while you wait for a new battery. Don't charge it either!
door
If you heated the battery, the fire may have been the result of that or if you were in a very hot location.
Commentaar:
The heat is not due to the location, you would have had the iPhone in an oven to get it that hot. This is clearly a shorted battery either due to a short on the logic board (tool crossing the power lines) or the battery is failing.
door
Voeg je antwoord toe
Nathan Fishman zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 36
