Big screw stuck in a laptop's small screw hole.
Hello, I put the wrong screw in to the plastic screw way/hole (whatever you call it) and it is now stuck. It is ph00 head (same across the laptop). Please help me to get it out.
Can I use superglue? or is there a better way to do it?
Thanks.
Is dit een goede vraag?
2 opmerkingen
use a small sewing/acupuncture needle to get you some wedge. Try then gently to screw it out. Or pour some glue on the needle to superglue it.
Let us know what worked. so others can follow it
door bmx2019
First, using superglue won't work, i tried.
I will try other methods.
door phalidel zhu
