Ga door naar hoofdinhoud
A garage door opener is a motorized device that opens and closes garage doors and is controlled by switches on the garage wall.
6 Vragen Bekijk alle
Lights don’t go on when door is opened or closed
Lights don’t go on when garage door opens or closes
Update (07/20/2020)
Light bulbs are fine
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
You're going to have to get a multimeter and start tracing this problem. Ours have relays that click on and off and if yours does, but it doesn't click, there's where to start looking. If you're not good with 120 volts, don't touch it unless it's unplugged.
Was dit antwoord nuttig?
Score 1
If it doesn't go on even when the light button is pushed, you may want to check the bulb first.
Score 1
Voeg je antwoord toe
Peter Provinzano zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 54
