Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Nintendo handheld device released February 2011, identified by model number CTR-001.
387 Vragen Bekijk alle
3DS lower screen green tint
I picked up a faulty 3ds a while back with a Green tint on the lower screen. I have tried replacing the lower screen and still get the same green tint with the new screen installed, I’ve cleaned the whole board and can’t see anything damaged that would have caused this and the rest of the 3DS runs completely normally no problems. As I bought it like this so can’t say if it has been damaged in the past somehow or anything. Has anyone seen this before and managed to fix it? Thanks!
Is dit een goede vraag?
Voeg een opmerking toe
SLA DE UPGRADE OVER
Bespaar door het te repareren met een alles-in-één kit.
Koop iPhone-reparatiekits
SLA DE UPGRADE OVER
1 Antwoord
Hi!
Yes, saw this before and somehow the green tint disappeared magically. You need to clean the connector where the screen goes in. Make sure if sits flawless and is not blocked anywhere or pressed to the case.. Also make sure nothing is making a short. You’ve tried 2 different screens, right? If you still facing this issue, it could be motherboard related and further investigation is required to solve it.
Was dit antwoord nuttig?
Voeg je antwoord toe
Evzie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 24
