Ga door naar hoofdinhoud
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
768 Vragen Bekijk alle
MacBook CPU constantly throttled to 0.8GHZ after iFixit battery swap
Hello everyone,
I have recently gotten my hands on a Mid 2015 15” MBP that was running slow, hoping I could get it fixed back up for personal use.
The previous owner had apparently swapped the old battery out with a new iFixit replacement one and then immediately sold the device as it has been running slow ever since. Using IntelPowerGadget on OSX or Task-Manager on Windows shows the CPU constantly being clocked down to 0.8ghz. This is definitely not thermal throttling as the chipset never exceeds 50C, there are also no faulty sensors when checking with HWMonitor.
The original battery had been discarded so I cannot check whether this issue is actually caused by the battery at all, however inspecting the battery visually and using CoconutBattery I can see that it is not an OEM battery since there is no battery serial number being displayed. Running the hardware diagnosis (holding the “D” key at startup) reveals that the battery might have problems but it says I should still be able to use the device without any noticable changes, showing the error code PPT004.
I then went ahead and bought this used original A1398 battery, thinking it was salvaged from another Macbook, however it ended up being some sort of refurbished third party battery causing the same issues again so I will have to return it anyway. The values shown on CoconutBattery are similar for both batteries (both less than 10 charge cycles, etc.) so I have just attached an image of the iFixit one below.
The machine itself is in mint condition, I have made sure to look for any water damage on the logic board but it seems perfectly clean, after all the device can be used flawlessly with the exception of it running at 1/4 the supposed speed.
I did come across similar threads however they were usually regarding older macbooks or were only having this issue intermittently when plugging in an external monitor, etc.
Others proposed just deleting the IOPlatformFamily.kext from OSX to get rid of the Intel Speedstepping feature, however this method is somewhat outdated and seems like a stupid idea anyway. A similar solution was being shared here, however that is again just circumventing the issue instead of fixing it, and even then Im not sure that would at all.
Essentially I just want to know two things:
  1. Is this throttling behaviour really linked to a 3rd party battery instead of a logic board fault, and if so, why would anyone buy or manufacture such batteries if they make the device useless? If this is the case there should have been plenty of others with this exact issue, yet I have only found a few threads discussing a similar issue
  2. With the iFixit as well as the other “genuine” battery not working as intended, where would I even begin looking for an actual OEM battery within Europe without having to get it replaced at an Apple store?
I never had any issues replacing the battery on a 2012 MBP, so Its fair to say this behaviour could just be another one of Apples shenanigans to get peoples devices fixed at Apple only and nowhere else, but I just couldnt find a definitive answer especially since I dont have the original battery to compare against.
I wouldn’t know where to ask otherwise, so any reply would be very appreciated!
Update:
I have tried using ThrottleStop on BootCamp Windows according to this thread, this does however also not work. Deleting the IOPlatformPluginFamily.kext as mentioned in the same thread is not an option since it does not even exist on my OS X Catalina installation.
Final Update (Found a solution):
So it turned out not to be a battery related issue . The person I bought the device from stated the issue appeared after swapping it for an iFixit replacement battery, but after buying yet another OEM battery the problem still persisted.
Instead, the issue was related to the CPU current sensing circuitry. I didnt manage to find accurate boardview and schematics for my specific model (820-00138) so I had to use this XinZhiZao (similar to ZXW tool) maintenance program which had the correct board layout to find the problem.
The issue was caused by the "SMC_CPU_IMON_ISENSE" line which is produced by the U7200 power management IC. This chip is responsible for measuring the CPU power usage among other things, and sends the signal through R5530 directly to the SMC. This line was permanently stuck at 1.8V which made the SMC read a high CPU power draw, so it throttled the CPU to 0.8ghz clock for safety reasons.
I ended up running a jumper (blue) from this line to ground, thus forcing the line to 0V.
This way the system now reads CPU current as 0W and I can finally use the machine with its intended performance. No lags, everything finally runs smoothly. It also no longer gets stuck in sleep mode after closing the lid.
Obviously this fix is only a workaround as I still dont know what was pulling the line to 1.8V, so I assume it was either the SMC or U7200 which shorted the line to a neighboring power line somewhere. I didnt want to risk ruining the SMC by reballing it so shorting the pad for C5530 to ground seemed easier to do. However this means there is a constant 1.8V short to ground so I might want to replace the jumper wire with a resistor to avoid losing much battery power being wasted into the short in the future.
In conclusion, the built-in Apple Diagnostics (Holding down Cmd + D on startup) did find an issue, however it was not related to the battery but rather the SMC or U7200. My assumption of having to use a OEM battery was wrong, as it also now works just fine with the replacement iFixit battery. I used HWmonitor on OSX to check the “CPU Package Total” readings, which were at 100 watts and above. After the fix it is reading -W, so the remaining battery time estimations might be inaccurate, but it technicallly isnt necessary.
Im not exactly sure how a simple battery swap could have caused this issue, but since I didnt find much information regarding Macbooks being throttled to 800mhz CPU performance, make sure to check all temperature and current readings using some sort of monitoring tool like mentioned above. A faulty temperature sensor might possibly cause a similar issue.
Hope this helps
Is dit een goede vraag?
Score 3
3 opmerkingen
Open up Activity Monitor what does kernel_task look like? If it's excessive that sounds like the system is in Safe Mode to protect the CPU from over heating.
I would run the onboard diagnostics to see if an error pops. Restart your system and press the D key
Reference: Mac startup key combinations
door
kernel_task never exceeds 20% in cpu usage, the only other thing is the already mentioned PPT004 error when running the diagnostics even though the battery condition is still being reported as "good" on OS X Catalina
door
Hey Daniel, I'm sort of having the same issue. However, in my case, throttling never occurs if I am plugged in or when discharging the battery at the 90+ range. Could this be SMC related? I ran apple's diagnostics, but couldn't find any issue. I posted my issue on fixit. Here the links : Very odd Cpu Throttle On Battery
door
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
At this point you’ll need to get the SMC logic fixed on your logic board as sadly you have corrosion damage around it which is the cause of the PPT004 error.
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
What SMC data lines could be affected? If they wouldn't, how else could the system read out the charge cycles, capacity etc. from the battery? I will still check SYS_DETECT_L and some of the other lines regardless. Would be good to know if third party batteries even allow for an unlocked CPU clock multiplier. Also, I have read on some threads about other people getting the PPT004 Error and they did not seem to get any significant slowdowns, not sure if they ran on older MacBook models however
door
You'll need to review the schematics to make better sense on how SMC is wired to the sensors (Temp, Voltage and Amps). Its a bit of work to debug SMC and the SMC chip its self could have an issue. Often liquid damage getting under it as its exposed to the drips from the keyboard and track pad areas.
PPT004 is a clue nothing more. It points me to the SMC lines.
door
I have finally managed to find a workaround for the issue. Unfortunately the only way was to disable the CPU package current sensing signal originating from the U7200 power management chip which is going into the SMC.
There was no corrosion to be found around the SMC, but it definitely was a problem with the SMC falsely reading too high of a CPU power draw.
See my updated post above for further details
door
In my experience, changing a MBP battery in and of itself would not cause the CPU to throttle back. I do not believe the battery is the cause of the computer’s problem.
Score 1
2 opmerkingen:
Correct! The SMC logic needs to be fixed.
door
This appears to be true. I have recently bought a OEM battery for my model and it did not fix the issue. I made sure to check the labels and serial number as to not get ripped off buying a third party battery again.
That being said, I managed to fix the issue using some soldering work (see above)
door
I've had this issue when installing a third party battery, though it wasn't a sensor problem as the CPU would go back to full speed when plugging in the old (horribly performing) battery.
I've found a solution just by turning the laptop on without a battery and then plug the new one in while it was running. It definitely doesn't feel right to plug the battery in while the system is running, though it did work and tried turning off/restarting without having the CPU issue anymore.
I shall mention that when the new battery was causing the CPU throttling, the new battery was recognised on system profiler or coconut battery without any problems. The issue might stand with the SMC/EFI software not being happy with the different battery.
Score 1
well i really need help here, i have a mackbook pro early 2015 Retina, after the original battery swell and we had it removed, the laptop started to work really slow.
Now i have bought a new non-original battery, the device is much more faster but i still have high CPU load, overheating and not to smooth Graphic problem... is this an SMC fault again?
Please... i really need help....
Voeg je antwoord toe
Daniel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 36
Afgelopen 30 dagen: 166
Altijd: 7,276
