How to change the logo when starting
Someone changed the startup logo on my DPM8000 and when I follow the steps to use a welcome.bmp image is does not change it back. Is that a one-time only change or how can I change it or take it back to the default Philips?
Is dit een goede vraag?
Hi @wttllc ,
Did you try this method to alter the welcome screen?
door jayeff
Hi @jayeff,
Yes I have attempted that procedure, reflashing the firmware and resetting to defaults but nothings seems to work. The firmware goes OK and removes itself from the SD card, but the welcome.bmp image does not change at startup and remains on the drive. That is why I was curious if it was not able to change repeatedly? Unfortunately I only have access to this one unit so cannot test on others. Thank you for your input.
door We Type
