Ga door naar hoofdinhoud
Bluetooth gamepad by Asus, sold with the Nexus Player.
My right axes goes leftward always
Hi, guys, i've just brought a controller Sven GC-2040 and start to configurate this for FIFA 20 and have one problem.
Sorry, I put wrong Device cause I couldn’t found my joystick.
You can see in pictures the issue. The right stick goes left always.
https://imgur.com/JxnUlTB
https://imgur.com/GiA7xkj
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Adamo Official  … this as a common issue that happens to all controllers at some point. the reason is either the internal housings bands that keep the stick straight are broken or stretched, or that there is dust or debris preventing the stick from returning to its neutral state. you can follow this guide to disassemble the device and attempt to clean the housing with isopropyl alcohol:
ASUS TV500BG Bluetooth Controller Disassembly
if cleaning doesnt fix the issue, or you see the bands are stretched or damaged, you can replace the controller housing. this will require tools and experience. the parts for this particular controller isnt advertised, but this is a standard part for controllers of this type. here is a link for a potential match ( youll want to verify pins and shape while you have the device open) , but you can see that this part is for playstation, xbox and possibly yours as well:
https://www.amazon.com/EEEKit-Replacemen...
if this doesnt match the profile of yours, just google joystick replacement parts and find a match.
post back with any other questions if needed.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Adamo Official zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 18
Altijd: 297
