Ga door naar hoofdinhoud
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1217 Vragen Bekijk alle
Phone will not power on after replacing screen
I just replaced a crushed screen. It was so bad I could not power off and of course now it will not power on….. any ideas?
Is dit een goede vraag?
Commentaar:
One thing I had tried when I had this issue when repairing an old 6S for a friend. Disconnect the battery and the screen cables, hold the power button down for 10-20 seconds to remove and residual power in the board. Then re-connect everything and ensure they all click/snap in properly.
door
Voeg een opmerking toe
1 Antwoord
With a '''USB mini voltmeter''' you can measure the power being sent to your device.
  • Plug the voltmeter into a powered USB port
  • Plug your lightning cable into the voltmeter
  • Connect the lightning cable to your iPhone
  • Power on your iPhone & watch the voltmeter
You’re looking for a consistent amperage (red number) between 0.9-1.0A being sent to the device during boot, and while it is running. If this number dips frequently or stays low, you are not just dealing with a display issue. It could very well be a charging port and/or battery issue.
Another thing you can test is the voltage on your battery using a multimeter. If it reads below 3.82V it means that it is not charged, or has failed in some way. By ruling out a potentially bad chargeport first, we can conclude after this measurement whether it is a battery issue or something else.
USB Mini Voltmeter Afbeelding
Product
USB Mini Voltmeter
$9.99
Was dit antwoord nuttig?
Voeg je antwoord toe
Patricia Cockerham zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 21
