Samsung Flex Washer Front Load Door Locked
My Samsung Flex Washer Door is locked. Wash cycle completed and i drained the water from the washer but the door will still not unlock. How can I unlock to get my laundry out.
Is dit een goede vraag?
Hi @skbgirl ,
Have you tried disconnecting the power from the washer for 5 minutes and then reconnecting and checking if the door can be opened? Just a thought.
Don’t know your model but have found the service manual which as far as how to manually open the door is not helpful.
You could try the manual mode of smart install test #1 as described and then step though to the end of the tests without pause to see if this releases the lock. Suggest that you don’t try automatic test or any other test in manual check mode as it says tests are to be done without clothing in the washer.
Sorry I can’t be of more help with this one. Washers are getting too smart nowadays.
Was dit antwoord nuttig?
Try this video. It helped me.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 20
Altijd: 1,158
5 opmerkingen
Hi @skbgirl ,
What is the model number of the washer?
door jayeff
@jayeff @jayeff WV55M9600AV/A5 is the model number
door Sherri
try the child lock
door Lori Penetar
I have the same problem. The door was unlocked put a load in and now it’s frozen and my door won’t unlock
Anyone else have this problem happen to them and how did you get it to unlock. I’ve tried everything the Manuel says to do but won’t work.
Any suggestions is greatly appreciated
door Willie Ramirez
https://youtu.be/ksVOofzxQkE
door Mark Sloan
