Ga door naar hoofdinhoud
Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
103 Vragen Bekijk alle
What’s wrong with my iMac and it’s LCD?
I recently got given this iMac by my father with the following problems :
I have replaced the LCD only and am now thinking maybe its a LCD connector issue with relation to the pixel scattering on the screen.
Then there’s the issue of it not actually booting up and staying on this console screen. I have a bluetooth mouse and keyboard for it but they seem to be useless until I connect them using the GUI.
Any help would be greatly appreciated!
ps i also think the disc reader has a disc stuck in it, how would i go about extracting it without buying an new one or breaking this one.
Is dit een goede vraag?
13 opmerkingen
This series needs a USB keyboard to control its book options.
door
I have one but it a regular keyboard used on my windows PC will that suffice?
door
Yes, that will work! See if you can get diagnostics to come up press the D key.
Mac startup key combinations
door
After running the hardware test, its says in the test results no trouble found, pass number 1 with total time tested being 7 mins exactly
door
Running an extended test as we speak
door
8 commentaren meer tonen
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
To eject a DVD, hold down your mouse button on startup.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thanks dude this got it dislodged
door
I’m not sure why you thought the issue was the LCD.
You are facing a kernel error within your OS files or it could be hardware. You clearly have a logic board issue as the graphics is messed up on the display, so I would have replaced is the logic board first:
20” iMac Core 2 Duo 2.66 GHz logic board Apple P/N: Rev-1 661-4984 or Rev-2 661-5136
You likely will need to reformat and install a fresh copy of the OS this system requires if you are still getting the memory errors.
Score 1
Voeg je antwoord toe
Roguen Walker zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 78
