Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus. Identifiable by the model numbers A1549, A1586, and A1589.
5105 Vragen Bekijk alle
Recently I changed my iPhone battery and now my touch screen is acting
Recently I changed my iPhone 6 battery and ever since I have changed it the touch screen is acting weird…. What must have caused it to behave like that?
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Another potential problem is if you are not careful when reassembling the iPhone, the top stack of components on the screen can be to out of position. This can cause the phone to close as easily as it should and leave extra pressure on the display.
Sounds like probably just an incomplete seating of as connecter though.
Was dit antwoord nuttig?
Score 2
Did you unhook the screen when you changed the battery? It might be a bad connection, try disconnecting the screen and cleaning the connections with a qtip and alcohol. Make sure you disconnect the battery before disconnecting the screen.
Score 1
Voeg je antwoord toe
Mini John zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 21
