iPhone 8 Plus Won't Turn on After Replacing Screen and Battery
Hey guys, recently I just replaced my iPhone screen and battery simultaneously. I put all together and it works great. However, I woke up the next morning to the phone completely dead. I thought it’d be a simple fix but my phone won’t reset, turn on, or anything. I’ve tried everything to figure out what the problem could be I disconnected the battery and put in the charger but the screen won’t turn on either so I took out the screen and installed my old broken screen with the charger and still nothing worked. I examined the connectors and everything on the phone but everything looked fine. I could really use some help here because I’m just in high school and can’t afford a new phone.
Is dit een goede vraag?
Did you try putting in the original battery? Did you try hooking it up to a computer and seeing if iTunes will recognize the phone?
door Allan Barr
Did you try a different charger? Have you used an aftermarket charging cable before?
door Allan Barr
I did try putting in the original battery and screen and arose with the same issue. I hooked it up to the computer and it refused to even recognize the phone. I tried an aftermarket cable then tried an original cable
door Tyler p
