Ga door naar hoofdinhoud
The larger edition of Samsung's tenth flagship Galaxy phone, released in February 2019. Shipped with Android 9.0 (Pie).
107 Vragen Bekijk alle
My Phone Is Water Damage
I have water damage s10 plus it's not turning on what is the problem with my phone battery issue lcd issue or anything else?
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
1 Antwoord
If it's water damaged it could be anything. Once it gets wet and has voltage running through it, it will start to corrode on the connections immediately. You will have to take the phone apart and clean it up and find any shorts and probably a new screen and you will most likely still have issues with the phone. Most repair shops won't work on phones that are water damaged except to extract data because of all of the problems and all of the future problems.
Was dit antwoord nuttig?
Voeg je antwoord toe
rashdiziad zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 1,890
