Ga door naar hoofdinhoud
Full Size Sedan sold to Police in North America as the Chevrolet Caprice Police Patrol Vehicle
3 Vragen Bekijk alle
How to fix my rear bumper?
Hi All,
Just wondering how I can fix my rear bumper.. What kind of materials/tools do I need? Or is it better to replace the rear bumper entirely? If yes, is there an manual for how to do it? (just wondering if there are any hidden screws)
It’s a 2017 Chevrolet Camaro (not the Caprice, was unable to select the Camaro).
If a picture is required, please let me know.
Is dit een goede vraag?
4 opmerkingen
Can you put pictures up please
door
@barriphone Picture is attached!
door
موقع زي الزفت
door
ما منو فايده
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
It looks like something punched a slot in it and it's cracked on the top. I am not a body man but I have heard it being done with bondo and a flexible additive. I would would check into that. You don't need to replace the bumper. That would be expensive and you can either blend in the paint for those two areas or for a better result paint the entire bumper. It's hard to blend clear coat but if you do the whole number and it won't be noticed because of the seam between panels.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thanks for your answer! Yeah it was already there and now it's the time I want to get it fixed :). Did some research and found something like this: https://www.walmart.com/ip/3M-Bondo-Stag...
Should that be enough? First I'll try to use the Bondo kit, otherwise I could paint it afterwards.
Thanks!
door
Voeg je antwoord toe
koppie007 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 238
